Backup/360° Camera Issue
GTPprix
Metro Detroit, MI
So my right side camera was going out quite a bit. Finally got a chance to look at the codes and its either the camera module or the VPM. Replaced the camera today hoping it not the VPM as thats a pain to remove; we shall see!
penncage
2022 Yukon XL with ~15k mi, same issue - cameras crapped out a couple of days ago. I have an appointment with the dealer tomorrow. Mentioned the TSB, they were aware of it but surprised my 360 cameras were also not working.
I will update on the resolution.
Dealer inspected for issues with wiring and found none. They think the VPM was corrupted and replaced it. Cameras work now.
BTW- our issue was a complete camera failure, not intermittent.
GTPprix
Metro Detroit, MI
Happy to report (and hopefully I dont jinx it) that my side camera replacement has indeed corrected my issue. Pretty simple as well!
viven44
Senior Member
Dallas, TX
Hi all, just wanted to report that on our 2024 Suburban Z71 -- after about 600 miles we had the same problem
- 360 degree button or camera button on screen had no effect when pressed
- Putting vehicle in reverse showed the error shown in the original post
Took it to the dealer. Dealer replaced Module 87816606 - Video processing module which looks to be a >$600 OE part and of course my guess is this part needs to be reprogrammed by dealer to accept the VIN of the vehicle. (Just a wild guess someone with more knowledge can confirm).
That has corrected the issue.
Scared about the future we are heading to with all the computer modules in these newer trucks
contenderv07
Scared about the future we are headiing
same here. We just got a Yukon AT4 with less than 300 miles on it and have this error. Have you had any issues since?
stels22
Приобрел Z71 23 года выпуска около месяца назад, и у меня периодически возникают проблемы с камерой заднего вида/360°, когда она не работает, может быть, раз в несколько дней. Я выключил зажигание и снова включил его, но это не помогает. После простоя в течение 20-30 минут все работает. У кого-нибудь еще есть такая проблема? Я знаю, что дилер исправит это по гарантии, но я бы предпочел не оставаться без машины ни дня, если есть простой сброс/исправление.
Такая же проблема, оказался заводской брак, разъем на видеомодуле не был припаян.
MikeG25
Picked up a ‘23 Z71 about a month ago and having intermittent issues with the backup/360° camera where it’s not operational, maybe happening once every few days. I’ve turned off the ignition and restarted it but that doesn’t fix it. After sitting for maybe 20-30 minutes then it works. Anyone else having this issue? I know the dealer will fix it under warranty but would rather not be without a car for a day if there’s an easy reset/fix.
I got the same problem. Could you solve it?
Vader97
