Replacement autoride strut coil spring assembly
MuttSr
Dorman is / was the only legit company making a loaded or complete set up like your looking for. 07-14 Escalade / Denali AWD and likely the 09> 2WD variant use the same front springs for z95 / z55.
You can get an OEM set up with AC Delco lifetime guarantee front z55 active struts for about $575 a side. I sent ya a pm with the info.
Don’t skimp on the strut bushings. Get the OEM GM version as the rubber material inside lasts a good decade and keeps the knocking away.
Do you think you can send me that info also. I need to replace my struts too, but I’m having a hard time finding the right ones.
Foggy
KS
In another thread this subject was discussed with the Arnott and Dorman
complete strut assemblies. I'm kinda in the same boat, but I don't think
that these 2 options really meet the OE design on the Z55 and may
not be a direct replacement
bruh2125
