GMT800Man90
- Joined
- Jan 4, 2025
- Posts
- 18
- Reaction score
- 4
I've got an 03 Suburban LT 4WD with problems that I just can't seem to figure out. So I'm hoping someone here can point me in the right direction.
Truck has 243k. I replaced a ton of things trying resolve this wandering, wobbling and loose feeling issue. And it's still all over the road and hard to control most of the time. The following is what I've replaced with brand new quality components.
Tires
Upper and lower ball joints on both sides
Outer tie rod ends
Pitman arm
Idler arm and bracket
Hub bearings
Sway bar links
Upper intermediate steering shaft and steering column bearing
Adjusted the steering box
Tightened the torx screws under the steering column covers
Alignment
It seemed better for about 10 miles and then has been the same since. I have absolutely no idea what else it could be. I just jacked it up and checked play and there is no up and down or side to side play. Truck has the stock 16" alloys on it.
Any ideas on what I need to check next? It has the stock shocks on it and came with the factory autoride suspension but has not worked in a long time and I've bypassed the system. But the factory air shocks front and rear are still on the truck. This is the 5th GMT800 I've owned and none of the other 4 have driven like this.
Thanks y'all.
Tires
Outer tie rod ends
Pitman arm
Hub bearings
Sway bar links
Alignment
Thanks y'all.
