03 Suburban LT Steering Issues, Wandering and Wobbly and Loose
G
GMT800Man90
Maybe start fresh and disconnect the battery for awhile, also touch both battery terminal connections--the vehicle harness connections--this should clear out any codes. Then reconnect and take it for a ride, going in and out of 4wd. See what happens.
Oh yeah I did that too. It didn't change anything unfortunately. It's just one of those things that's driving me insane. Because I've had 5 of these trucks and this is the only one that's been like this. I've had an 01 Yukon XL, two 04 Suburban's, 04 Sierra and now this 03 Suburban. Every other one had the same kind of mileage except my 04 Z71 Burb had 330k. They all drove great and had no issues like this. It's just super strange that I'll throw it in auto 4wd or 4lo and start driving and it pops up service 4wd but in auto 4wd it'll drive and shift just fine. In 4lo it won't shift. 4hi it doesn't throw the message and is just fine. When service 4wd comes up, it won't let me change the selection. I have to shut the truck off and turn it back on and then I can switch it. And when I go in 4hi or 4lo you can hear it switch and clunk and switching back to 2hi from 4hi or lo you can hear it switch and clunk again. Putting in auto 4wd you don't hear anything
Think the 4wd switch could be bad? The one on the dash with the 4wd buttons. They do occasionally go bad.
G
GMT800Man90
I don't think so because when you switch into 4lo and back out of 4lo you hear the clunk and switch. I don't know if it's supposed to clunk going into auto 4wd. From what I read it locks the front axle but doesn't engage until it detects slip. Putting it from 2hi to 4hi there's no noise. I haven't had to use 4wd in one of these trucks since winter of 22, so I don't really remember. I kept my Sierra in auto 4wd and never had an issue
89Suburban
Bull in the china shop
SE PA
What about the jounce stops are they in good condition?
It shouldn't "clunk" going into AUTO. Each mode change should produce a short "whirring" sound, if it's anything like mine.
In AUTO the front diff is NOT engaged until rear wheel slippage is detected; that's when the front diff actuator is commanded to engage the diff. But the transfer case is spinning the front prop shaft at the appropriate speed so when the diff does engage it will be relatively smooth. That's why the various speed sensors are in the drivetrain.
2drTahoe97
