SOLVED -OK, I give up.. How to unplug the cigarette outlet / center lower dash????
mountie
I am cleaning up my accessory wires, plugged into a triple power outlet in the cubby, front of the cupholders.
I have the panel out, but I can't figure out how to carefully remove the cig/power wires from the FEMALE outlet.
( I want to make an access hole on the side of the panel, inside the cubby, but I want to remove it first.
The side of the plug has an opening, you push inward, to release.....
FYI...... This is what the part is called.......
Dflo92
