How much DOES your right foot weigh?Welcome to my 09 Esky 6.2L in town driving on e85
I wanted a 10 SP for Xmas but they only had 6 SP last year.
I find it interesting that most normal people driving as they normally do,
tend to get less MpGs / consume more fuel per unit of time compared to the CAFE MpG test scores.
That being the case, why hasn't the test been amended to correlate more closely with how normal people drive?
Must be related to Wes! @DoubeleiveWelcome to my 09 Esky 6.2L in town driving on e85
I actually had mine up to 13.4 yesterday taking my daughter to the airport, cleared everything out and didn't floor it except once lolMust be related to Wes! @Doubeleive
My wife is back in the 9s again on E85. She loves the new gears and likes the newfound acceleration.
Can't argue with that. However ...Because they are terrible drivers.
This is actually why I'd let cabdrivers and other people who 'drive for a living' submit their MpG records,Zooming through traffic, making lane changes every few car lengths and then running towards a red light at ten over the speed limit until the last seconds.
They're nuts. Not to mention the swill they fill their tank with and lack of maintenance that kills their fuel efficiency.
Your driving meets your vehicle's CAFE estimates.My pickup meets its EPA estimates.
Is it a 2500? If its curb weight is high enough, it doesn't get tested.My Yukon XL was not rated by the EPA, big fat blanks on the window sticker and no listing for it at FuelEconomy.gov.
I emailed the EPA as to why, they had no answer for me.
Error 1. Overall you are using an overly simplistic equation of state to describe a system that operates via heat and mass transfer.
Error 2. Pressure is a measure of restriction in a flowing system. You are conflating mass flow of air with a measure of upstream pressure (in the intake manifold).
Error 3. You are assuming manifold pressure is equivalent to pressure at BDC of intake stroke. If it was the same, then how is anything flowing if there is no additional motive force from pressure drop?
Error 4.
The natural and logical inference from this is that, for every increment of displacement I remove, I gain cylinder pressure at BDC. The higher pressure at BDC means the smaller engine maintains the same power as a larger displacement engine.
