Antonm
- Joined
- Apr 2, 2024
- Posts
- 348
- Reaction score
- 361
Negative there ghost rider, not true, not even a little.Error 5. You are taking a specific operating condition for a 6.2 and substituting it into a 5.3 and assuming the only variable that changes is manifold pressure. If/when throttle opens up a bit, so does engine speed. Edit: see engine dyno example below.
Engine speed (RPM) is dependent on the ratio of power production to load.
If the engine is making more power than the load is holding back, engine speed is goes up. If the load being applied to the engine is greater than what the power the engine is producing, the engine speed goes down
We'll talk about this two ways/ give two examples of how you're wrong.
1.) First lets use your own engine dyno example (because you brought it up). An engine dyno places a load on the engine that can and is varied. Have you ever seen an engine being broken in on a dyno? The dyno operator will set the engine at some throttle position/ power level, then vary the engine speed up and down by raising and lowing the engine load. So the throttle position is not changing, yet as they lower the load engine speed goes up, and as the raise load engine speed goes down.
And the dyno operator can also park an engine at any speed (RPM) they want and just leave it there. This is sometimes done to heat soak the engine to simulate a towing condition.
Even during the dyno power pulls the resistive force/ load on the engine is varied to give a consistent rate of engien speed change, 300 RPM/ sec is kind industry standard. You can actually cheat a dyno by making the rate of change slower/the sweep time longer by reducing the rate of change to say 200 RPM/sec, because at the lower acceleration rate some of the power that was being used to accelerate the engines rotating mass can be absorbed by the dynos load cell, which makes it look like the engine made more power.
2.) Real world/easy to understand examples that don't require knowledge of dyno operation (which you obliviously don't have).
Have you ever driven a manual transmission vehicle and killed it with the clutch by letting the clutch out to fast? I have , a few times actually. Not terribly long ago I was teaching (well trying to teach anyway) my oldest son to drive a stick, he revved up the engine to about 1500 rpm , basically dumped the clutch, and the engine shut right off.
So while the engine had no load, it was running fine, he even opened the throttle some, but when he applied more load than the engine was making, engine speed went down (all the down in this case).
Here's another easy real world example that perfectly demonstrates that engine speed is determined by the ratio of engine power to load applied ,,,ever drive up a hill??
If you kept the same throttle position (and same gear selection) trying to climb a hill as you did driving on flat ground, the engine rpm would go down. Heck if its a steep hill, you might open up on the throttle and still have the engine speed slowing down.
And while this post is already getting to long, the whole discussion this was taken from was/ is abuot two engine of different displacements making the same part throttle power at the same RPM. And it even states that in your own damn equations that you don't apparently know how to read or understand. The "N" in the numerator of your power equation is engine speed.
