The KidWagon
Installed my Improved Racing thermostatic trans outlet and the smaller Derale 10-row instead of the TruCool 40k.
Hard to say if it’s “better” since it’s been under 40° here for quite a while.
I will say, with the 40k installed, sans radiator loop, I wasn’t even achieving 100° trans temps on my way to work. Now I’m able to achieve 170°, allowing for moisture to evaporate from the ATF.
Once it warms up in May, I’ll know whether the Derale is enough to keep up with high ambient temps and a 3200 rpm stall.
Imgur link to photos
I have a Derale in my setup with a 3k converter, and it works great. Trans gets warm enough but never hot. Stays under 200°
KidWgn
KidWgn
Certified Kid Hauler
St. Louis, MO
Which one?
This one is rated 20k BTU.
I’m hesitant to believe it will keep up. Around town driving I’m already climbing over 200°. It drops rapidly once there is airflow over the cooler, but any type of stop and go stuff raises it quickly.
I’m going to order some stainless braided line and re-route the lined once I get some time. Currently they are routed past the exhaust on the driver’s side with heat sleeve over them, and I think that’s a contributing factor.
ivin74
05 NBS Nali
Htown, Texas
Which one?
You may need to tune the electric fans to kick on earlier like @ 180*.
89Suburban
Bull in the china shop
SE PA
Which one?
Good to see you floating around.
Which one?
It was part of a complete cam build kit I had bought years ago for my 03 from a shop. I looked but I can't find which one I bought. Sorry.
kbuskill
NE. FL.
Which one?
The 6 speeds run the trans cooler on the driverside?
KidWgn
KidWgn
St. Louis, MO
No. The factory hardliners were ran around the passenger side. I ran all new rubber with heat sleeve around the driver side.
I need to order 40’ of stainless braided stuff and an assortment of AN fittings and make some permanent lines, routed better.
KidWgn
KidWgn
St. Louis, MO
Hey remember when I said I needed to re-route the cooler lines? :banghead:
Saturday we took my step-son to the Wolf Sanctuary, about 40 miles from home. On the way back, I started seeing smoke behind me and pulled over.
Tranny line--wrapped in DEI heat sleeve--had shifted over slightly and was rubbing against the tail of the stud from manifold to crossover pipe. It rubbed JUST enough to make a pinhole and spray ATF all over the undercarriage, exhaust, and COVER the entire rear.
I spent Sunday re-running new lines. This time I went above the transfer case, then against the splash-shield, and straight up. Pics incoming...
KidWgn
KidWgn
St. Louis, MO
Finally got around to having the new TPMS sensors installed.
Here's a fun one...they work fine right after programming; as soon as I power the truck off, they lose programming.
Remotes work fine and never lose sync.
Crossposting to the 07-14 electronics section
bigbully
