Need support. Just found out my radiator is leaking
The new replacement OEM GMT 800 radiators don’t have petcocks either, they eliminated them also. I replaced the one in my 02 Yukon Denali a couple years ago and it came without one. My old one had it.
iboughtatahoe23
iboughtatahoe23
My stock 07 Denali does NOT have a petcock.
I pull my lower radiator hose off to drain it.
Your results may vary?
Youd think seven years later they would implement something like that.... than again half a million in savings haha across all gmt 900 made
I never mess with the petcocks even if they're there. I just pull the lower radiator hose.
Try and get it into a bucket or pan so it can be disposed of properly. Methods may depend on the type of coolant. Search for recommendations in your area. https://www.autozone.com/diy/antifreeze-coolant/what-to-know-about-disposing-antifreeze
Ethylene Glycol is poisonous so anything splashed on the ground should be absorbed or diluted enough to not harm animals that might be inclined to lap it up. Had a friend's dogs get into some antifreeze in his garage and both dogs died from drinking it.
Blackcar
Fluid should be captured if dog or other animal drink they will die.
Need to check in your area who will recycle anti-freeze.
iaminfiji
