New member: 2025 Tahoe High Country
T
tyet
Where did you get those black accents? Is that from the dealer?
See my post above, as i just listed all the part numbers. i removed all the oem chrome parts and replaced them with the oem black parts from the RST. The bow ties i had custom painted. All the black badges are oem from dealer as well.
Julez
Curious on your chrome delete progress? Were you able to locate OEM window trim? Also what chrome did you delete on your grille?
Should be getting my ‘25 HC soon and will be going through the same chrome delete process.
Disregard… I see you posted previously
Julez
In case this is helpful to anyone, here are the part numbers for the oem black parts. This will black out every single chrome thing on the vehicle. Depending on where you get parts from, you are looking at around $2000 in parts (the grill is the most expensive at $511)
84496227 bezel
84496193 (S)COVER
13526766 (S)HANDLE
85590194 MOLDING
85590195 MOLDING
84844389 MOLDING
84844390 MOLDING
85649797 RAIL
85649798 RAIL
85136434 MOLDING
85136435 MOLDING
84977518 F FASCIA
86545889 R FASCIA
85775020 Grill
I’m using a genuine GM parts dealer site, did you have an issue with the site saying the parts don’t/didn’t fit your vehicle?
zephyr
