02 Sensor
tedward
I have a 99 2dr tahoe with 4wheel drive, does anyone know how to replace a 02 sensor? Thanks for the help as always!
LI99HOE
Top Notch Tech.
N.Y.
You should have 4 of them Ted.
2 pre-cat, and 2 post-cat. Just poke your head under there, and you'll see 'em.
Don't forget to clean each of the bung's threads before you install the new ones.
T
tedward
The check engine light came on . My mechanic said the 02 sensor needs to be replaced.
L8RH8R
I have a 99 two wheel drive and just did a cat back exhaust today. There is an O2 sensor just after the cats.
MRBJU52
