03 GMC Yukon Denali Lift Kit
Bxcliff
New York
I'm thinking of lifting my Denali with this kit
https://www.google.com/url?sa=t&...egQIAxAB&usg=AOvVaw0eaLxD6Wf9HKHBBAP0trSm
I've been told by others it would fit my truck but I'm concerned about the angle of my CV axles without the use of a diff drop bracket
Would this lift cause too great of an angle for the CV axles? Or would they be fine to run as others have said.
Sent from my SAMSUNG-SM-J727AZ using Tapatalk
HiHoeSilver
Away!
Chicago
CamReynolds
it would be stretching the cv with the 2 inch spacers but a ton of people on here do it with no problems. do you offroad alot?
Bxcliff
Bxcliff
New York
Not as much as I would like too, can't really off-road that much in my truck, it just doesn't have the proper setup to do so.
But I'll take what you said into consideration thanks brother
HiHoeSilver
Away!
Chicago
If you're going to level using keys, the general consensus around here is 2.5" max, better off going 1.5-2". How big of a spacer you put in back is really up to you depending on how much rake you want to keep (or not).
Bxcliff
Bxcliff
New York
Noob question, but I've never messed with a torsion bar or keys, I know that's the adjustable portion but how does it work to adjust the level?
06JET
Wisconsin
Goggle is your friend. Anything you want to know about adjusting or removing keys.
I did 2" spacers and 2" on the keys up front with a 3" body lift and it worked out great with 295/60r20 Cooper STT Pro's. Looks almost factory, but better.
CamReynolds
yeah he could crank them 2 inches and get spacers to level it but 3 inches is a lot
audley71
