So, when you first attached the gauge, before even touching the key, it had 46 psi showing? And then when you shut the engine down and watched the gauge it dropped to 4 psi? How quick did the pressure drop?
When i attached it before even putting in a key it was zero. Put in key turned to on position without start it did 46-48 multiple times46-48 when? First attached? Or after you shut off and it held at 46-48? Please be more detailed with your answers.
Almost 200k no idea if pump or fuel filter has ever been changedHow many miles on this truck, and do you know if the fuel pump has ever been replaced?
