DonnieBrasco
- Joined
- Sep 11, 2012
- Posts
- 114
- Reaction score
- 4
2003 Yukon with about 225k miles. Driving down the interstate yesterday and all of a sudden it starts dinging, traction control turns off and it says "reduced engine power" and I can't go over about 20 mph and 2k rpm. Got it towed to my house to try and figure out what's up. I've been reading some about this and have myriad options to look at and was hoping y'all could help me narrow it down before I start throwing money at it. Here are some things I am thinking...
Disclaimer: I've had an issue for a month or two with my evap purge valve (the one on the engine) but I highly doubt that's the issue that's causing this. Granted, it may have led to whatever is causing this but I don't think that alone is the issue.
- Battery and/or alternator. However, the truck still cranks up, power locks, instrument panel, etc. all work. So could I rule out battery and/or alternator just based on that?
- Throttle body wiring harness and/or sensor. Currently this makes the most sense to me. I've read about people having issues with the wiring harness on the TB. I'm going to open it up tonight and see what it looks like, see if the actual TB is gummed up or if the wires are frayed or anything.
- Ground for PCM. There's a ground connection for the PCM on the passenger rear of the engine. I've also read about G103 next to the right cylinder head. Are these the same grounds or different?
