SybrKnite
Okay first about the Tahoe.
2005 2wd Z71 trailering package 5.3 Auto 147K stock.
After having the Tahoe for 6 months now with no significant problems it began overheating. Driving down a city street at 35 mph noticed the ac got warm and had the HIGH COOLANT TEMP warning come on so I immediately shut off the ac. Stopped to check it out and temp spiked at 250* according to the cluster gauge. No leaks, full reservoir and electric fans both running high. Shut it off to cool and then began driving and spiked again at a stop light. Pulled up on freeway and it dropped back down to around 205 (normal for me). Temp stayed there after several miles so turned the ac back on. Continued driving for a while; even in stop and go traffic with no problems. Got home let it sit idling with ac on, then off with no overheating problems. Two hours later drove to the store and after 5 minutes the temp ran high again. Shut it down then 30 minutes later again on the 5 minute round trip home. Four hours later driving to a friends house it spiked again. Shut off ac and cranked the heat to high and it dropped to around 230* and never got cooler or warmer (night time) till I got home.
Figured it was a faulty thermostat so went and got one with more orange antifreeze. Tested the old thermo in water on the stove and it opened fully at 200* give or take according to my wife's kitchen thermometer. Tested the new one and it opened at the same temp. Replaced the old thermo and filled the radiator and purged it of air. Let it run for a while, no ac, and temp sat at 205* for a few minutes then began rising, fans came on in high speed and continued slowly to 250* so I shut it down.
The radiator pressurizes properly and is clear of any visible debris including the condenser coil, oil cooler and trans cooler. The upper hose seems really hot compared to the lower.
Coolant temp sensor? Water pump not moving coolant the way it should? Can they get weak? Changed a few water pumps on my C/K but not this style. Do they function differently?
Thinking of seeing what it does idling with no thermo installed just to see, but other than swapping in new parts I, which I rather not do...I am at a loss...
I have a meter but no scan tool or hand held temp gauge.
Any advise or comments are welcomed.
