05 Tahoe no cats
D
Dcolli9881
All that gas that was being added probably caused the cats to go bad.
What color is your startup smoke? Blue or black? Probably blacker than my java...
If your scan dongle and app can read it, when it's warmed up and at idle speed, what is the MAF reporting in grams/sec? Has the MAF been cleaned recently? Is the intake tube intact from the MAF to the throttle body, with no leaks? All vacuum lines connected and in good condition?
Do a standard fuel pressure test (key on, engine off, turn the key to "on" but don't start the engine). Then what is the fuel pressure at idle speed?
Freeze frame say maf is 2.8lb A minute
Fuel test was good when I did fuel injectors and after a couple of days
Everything is connected to my knowledge
Maf has been cleaned and no known leaks any where planning on doing a smoke test when the kit gets here
Smoke is white
Only problem I’ve had with it is evap but it’s just been on fill up clicks off every few seconds but the lines are clogged with bbs from canister just gotta drop the tank and clean them (plan on replacing fuel pump and canister etc when I drop tank ) wouldn’t think this would effect mileage cause it hasn’t for about 7k
ivin74
05 NBS Nali
Htown, Texas
Have a massive drop in mpg
Smoke from exhaust on start up
Goes away after you start to drive
Rough idle at start up stops after so long rough idle starts back when you go to park
Replaced 02 sensors 2/3 times before doing a cat delete cats were bad
Gas problem was before cats got deleted
Replaced fuel injectors
Coil packs
Spark plugs and wires
Long term fuel trim reading 25
Short term fuel trim reading 55
Any insight on what might be the problem
Did you use oem parts?
D
Dcolli9881
Everything but fuel injectors 2/3 fuel injectors were slightly black on the bottom thought that was the problem helped some but not allot
You should see if your app can be changed to read g/s, but if my conversion is correct the MAF appears to be a problem:
The MAF value -- in g/sec -- at hot idle should be close to what your engine displacement is. I assume that's a 5.3L engine, but the ECU thinks it's a 21L engine (!) based on the MAF, so that would 'need' more fuel.
Unplug the MAF for a test to see if it runs any better without it.
So I'd recommend to replace that MAF with a GM OE one, or a known good one, to see if the issue is alleviated. Re-read the MAF reporting value after that.
Hope you saved your OE injectors; they're probably much better than something bought online (if that's what happened).
D
Dcolli9881
Will be my next change i got some from a premium I’ve used them once before in a pinch and they never gave me trouble before on another vehicle
Backing up a bit, was the freeze frame data at idle? If not, we need to see what the MAF is reporting at hot idle.
Zues
