05 tahoe weird blower problem
SteveCZ28
Greene,Ia
im having a weird issue with the front blower in my 05 tahoe with electronic hvac. when truck is sitting idling, you can hear the a/c clutch cycling, but the blower wont blow air. so i was driving with the windows down, then randomly the blower started blowing air again at id say about half speed. so i roll windows up and all is good. i get home and pull in the driveway, and put truck in park. blower goes back out again. so i pulled blower out of its housing. fan spins freely. i hooked it up to a battery and it works awesome. when i bought the truck a year ago previous owner said he installed a new resister, and from what i can tell it looks like its been replaced and he did spice in a new plug end. the reistor thats currently in truck just looks like a big alluminum heat sink, and doesnt have a resistor on the end like im seeing on most resistor/modules that ive looked at. is it possible the blower resister is shot again? or am i looking for a different issue??
SteveCZ28
SteveCZ28
Greene,Ia
just updaing this incase someone searches and has a similar issue. i bought a new resister/module, plugged it in, and the fan operates like new again. honestly i think it blows harder now, than it did before resister/module went out (thats what she said, haha)
Rivieraracing
Glad you got it figured out, wish I could have helped but never have encountered that problem yet! Thanks for the update!
alc5m
you figured it out before i saw this, lol, i had the same issue, make sure you replace the wiring too if that had corrosion, i got lazy and had things to do when i did mine and just left the wiring with a bit of corrosion so mine is slightly intermittent, i wish i had a picture of the old resistor though, green everywhere
also if you have the auto controls be prepared to spend 105 dollars from a local parts store, otherwise its like 40 bucks for the non auto
SteveCZ28
SteveCZ28
Greene,Ia
i replaced the wiring also as it came with. and put a dab of dilectric grease on it.
i only paid 55 for mine with auto controls. helps to google part numbers :)
SteveCZ28
SteveCZ28
Greene,Ia
i replaced the blower motor resistor. some sites call it a blower motor module.
smcnair
you should put up the part numbers and / or where you purchased...
blatta1999
Did the new resistor you have only have the plug out that went to the motor fan? My stock one has two sets of wires going to it but all the ones I see online only have one. I have automatic controls in my 2005 tahoe.
MrBk22
