'05 Yukon Transfer Case Control Motor
wheels295
Nor Cal
Just wanted to share my experience with my Yukon for anyone else who may have had the same problem.
Over the last few months, I noticed my Yukon would automatically put itself in 4WD Auto. I would put it back in 2HI and go about my day.
Last week it did it again so I put it back into 2HI and drove it to the store. When I went to leave, I put it in reverse and it didn't go into gear. I tried drive but, the same thing. I put it back into park and I heard grinding.
I put it back into 4WD Auto and it went right into gear. I drove down the road and put it back into 2HI to see what would happen. It worked fine for a mile or two then it started slipping, then went out of gear. I pulled over, put it back into 4WD Auto and it went back into gear.
After doing some research I discovered that some people had the same issue and the cause was a worn out Transfer Case Control Motor.
I purchased a new one and after a lot of yelling, frustration and bruised knuckles, I replaced it and it solved the issue.
I hope sharing this experience helps and let me know if you have any questions.
Thanks all
Jayhawkeye3
