L87 6.2: “NHTSA to investigate potential for engine failure in nearly 1 million GM trucks, SUVs”
RG23RST
I think this is accurate.
The failed bearings I've seen so far look like contamination or a light to moderate oil starvation. Both can look similar on failed journal bearings for basically the same reason--deterioration of oil film integrity.
The oil flow diagrams you've linked to are helpful as well. It does show that the #1 and #2 mains could be more susceptible for damage from loss of pressure.
If a 2 stage pump is glitchy switching between stages it could cause a momentary drop in system pressure (how much of a drop, who knows?). it may also cause a miss timed switch event on lifters. I wonder what the correlation is between failed rod and main bearings and damage on lifters and cam?
5.3 and 6.2 have different oil pump part numbers so I can believe they would be different pumps.
This problem didn't exist before MY21 on the L87. It's not an oiling issue. The 5.3 and 6.6 would suffer the same fate if it was because they're the same design. Even with the oil control solenoid commanding "low" pressure it's still anywhere from 20-48psi or thereabout. Get on the gas and into high RPM the solenoid will command higher pressure up to 80psi or so.
I don't have any inside information so just speculation but I'm curious if the failed 6.2 engines came from Tonawanda or Spring Hill. Spring Hill had a bad batch of 5.3s get out that were put on stop sale. The out of spec lifter bore issue also came from Spring Hill.
RG23RST
In today's modern manufacturing, there is no excuse for cleaning out chips, debris, or FOD (That's what they call it in the aircraft manufacturing world..) As someone who has worked in the aircraft engine industry. this would get you disqualified as a supplier immediately. 2 main things....foreign objects and parts that are out of tolerance. More than one instance of this and you are out. Evidently this criterion doesn't apply with automotive suppliers or GM's internal manufacturing.....
Aircraft engines aren't produced by the millions though. Any mass produced engine is going to "make metal" more than a low volume engine sold at high enough price to warrant more specialized manufacturing and preparation.
PPK_
Oklahoma City
I have had a 5.3 from ny and one from mexico… i did not know spring hill made them too… i do agree one site might a problem in assembly..
blanchard7684
Senior Member
Good info thanks.
Stbentoak
Whether you build one or one million, that doesn't matter to the person that got that one bad one. I've worked in high volume atmospheres and unless you adopt the philosophy of, we will make them "Right 1st, and Fast 2nd" your business is doomed to die a slow death.
blanchard7684
Senior Member
A follow up on this.
My understanding is 5.3 has a single stage oil pump vs a 2 stage on 6.2. Edit: looks like the l83 does have two stage oil pump.
It also looks like part numbers changed on 6.2 oil pumps. For instance a 2019 oil pump is a 12686433 part number vs 2024 is 12733670.
(5.3 oil pump part number is 12733671 across same time frame)
Oil control solenoid stayed with same part number over same time frame (12686431) on 6.2.
PPK_
Oklahoma City
Is the oil pressure sensor near pump the or at the end of the what journals and cam lifters that are oiled? I mean each journal as you go away from the is going to have less pressure..
blanchard7684
Senior Member
The solenoids are in different locations.
jfoj
From the diagrams it appears the oil pressure sensor is mounted on the rear of the DFM manifold that is on top of the engine. So in this case the sensor is at the beginning of the oil flow path which is typical of most engines, but with all the DFM gear and the 2 stage oil pump, it would have probably been wiser to have the oil pressure sensor at the end of the oiling path.
This is what happens when you take a basic 60+ year old design and just keep adding bits and pieces on it over the years.
For reference I was able to obtain oil pressure values using a more advanced scan tool.
Approximately 28 PSI warm idle in gear
Approximately 33 PSI warm idle in neutral
Approximately 46 PSI @ 75 MPH at approximately 1600 RPM
The oil pressure did appear to boost past the 1/2 way point on the dash gauge when passing and the RPMs were up. Hopefully I will be able to graph the oil pressure behavior so I can get a better idea how it is controlled.
