05nali's HOW TO Ipod/AUX hookup for 03+ XM equipped trucks
maduro
NY
Hello, You are looking for 3 wires obviously. The ground wire is black with a white stripe. Your 2 audio wires are brown/white stripe and a green/white stripe. I was skeptical about this mod even working and it actually works great. Cheap and simple. Plus you do not have to change head units. Anymore questions let me know. Good luck
Hi Red/05Nali,
Sorry for the dumb question but am I correct in assuming that I am stripping down a portion of the mentioned wires currently from the xm receiver attaching my new wires to them & then running the other ends of my wires to the aux input I'm installing?
BillBlatt18
BillBlatt18
Latham, NY
Hi Red/05Nali,
Yes that is correct
Sent from my jailbroken iOS6 iPhone using Tapatalk
04blackout
Nothing like digging up an old thread, but I got a quick question... will the posts on these aux jacks accept female spade connectors or do they have to be soldered? I don't have a soldering iron and my skills blow, but I can crimp like no bodys business
My local shack didn't have any, so I'm gonna have to order online
zieglerj-pdm-specialist
in 100 degree sandbox
So I did this install and a couple requested that i do a write up, so here is the write up i followed here:
http://www.gmfullsize.com/forum/showthread.php?t=230249&highlight=how+to+ipod+hook-up
The info from original thread is quoted
Looks like this:
It can also be found HERE on ebay for half the price.
I ordered one of those so i can mount it in my dash, but for now I bought THIS one at radioshack. Works peferct, just isnt long enough to fit through a hole in the dash. And it CAN take the heat of a soldering iron. I soldered my connections.
NOTE: If you get a different jack, make sure it is STEREO not MONO
You will also need a 3.5mm male to male cable to go from your phone to your jack. I bought THIS cable at my local radioshack along with the jack. Before anyone asks, the blue cable is the shit. Gives it that nice "custom" look. :rocking:
I took off the lower part of the dash to make this more accessible. The tab is blue. Just pry it up with a screw driver. Then behind that is a smaller black tab that if you push in, the harness will pop out. Locate the green/white, brown/white, and black/white wires. The black is your ground and will connect to the longest post on the jack, or if you used the one I bought, the top post on the side. Also, there are two black/white wires. The one you want to splice into is the one farthest down on the right corner. Here is a bad pic i borrowed from GMFS since i forgot to take pics. :facepalm:
This mod works perfect, sounds great, and best of all, IS CHEAP! I use it with my DROID and my Ipod. Looks good too, and factory if you don't use a blue cable hahaha. I did the write up after the fact, so anyone who does this let me know if I left any details out. I will update the thread with some more pics when I get back to my truck this week.
Edit: Make sure you unplug your device while listening to xm otherwise normal XM will have decreased volume or will not work. Once you unplug your device from the cable XM will function normal again.
UPDATE: I got the amazon jack today and soldered it in and mounted it in the dash. Pics below:
Sorry for the ****** cell phone pics. Gives you an idea on where to mount. Once again this is the jack I used:
With the look of your Beautiful Denali its weird that you dont have an after market Radio that has an Ipod jack already installed? One that has where you dont have the Blue wire coming out. I have an Alpine D310 in my 04 Denali XL with the Ipod connection to it so you can have the wire ran into you middle console and you can run it with the head unit. Im not disrespectful at all..I was just wondering what radio do you have in that awesome denali? Great post by the way for the people who have a stock radio.
BillBlatt18
BillBlatt18
Latham, NY
I actually now have a pioneer z110bt double din lol. Definitely a nice upgrade
Sent from my iPhone 5 using Tapatalk
06GMC5.3L
Great write up. I might do this.
Sent from my iPhone using Tapatalk.
MurdrNali
Blue Springs, MO
Super easy job thanks for the write up! Did this tonight in my Denali. I mounted mine into the blank filler plate next to he TC button. Honestly I might have had 20 minutes in and 10 bucks in parts after buying the tap splices, aux jack, and speaker wire. Well worth it my opinion!
SteveCZ28
Greene,Ia
can the op clear something up for me please...which of the 2 jacks that are pictures is the one that can take the soldering iron heat? as when i do this ill solder as well for a secure installation
BillBlatt18
BillBlatt18
Latham, NY
There Are actually 3 terminals on the jack and I soldered all 3
Sent from my Galaxy S4 using Tapatalk 2
SteveCZ28
Greene,Ia
yes i do realize there are the 3 terminals. my question was which of the 2 jacks that you showed pictures of were able to withstand solder heat.
i was asking as i couldnt find that top jack (the round one) anywhere, as the ebay links ran into a dead end and found out that seller doesnt offer them anymore. but right before i logged off lastnite, i found the round jack on amazon and was able to purchase that, so that kind of solved my question. cant wait to get my jack in the mail and listen to my songs on my phone, as im too lazy to transfer songs from phone, to pc, to burn to a cd lol. trying to save some steps :emotions133:
valentinitoronto
