07 up plug and play airbag rear system!!
Nosho47
Nosh,
Lookin good man.
What shocks are you using with the TBSS bags?
Tony,
What would the TBSS bags be compared to a 4", 5" or 6" drop?
Also, what else would have to be done to run these bags? Link mount relocator?
Thanks
I'm using the belltech sp shocks. The rear ride is smooth with the tbss bags. The problem I am having is only with the front. I have the avs front bag bracket with slam specialties re7's with no shocks and the ride is bouncy. I will probably pick up djm control arms and replace the stock arms since the stock arms are made out of cast. I will be able to weld shock mounts onto the djm arms
Sent from my XT1254 using Tapatalk
992dr
Eastern N.C.
Thanks for the info.
I didn't like the BT sport shocks on my previous Tahoe, not as "sporty" as I was expecting.
When you say smooth, do you mean like a Caddy?
I'm looking to keep a firm ride.
NORCAL SS
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
You want stiffer better off going with springs and swaybar
Nosho47
Yes... It rides like a caddy. If you want a firmer ride, you should stick with springs IMO
992dr
Eastern N.C.
Thanks for the info Nosh, I appreciate it.
---------- Post added at 09:34 PM ---------- Previous post was at 09:32 PM ----------
Sorry Tony, I didn't see your reply earlier.
I'm thinking about your 6" coil with some good quality shocks adjustable shocks.
I still need to check y sway bars to.
NORCAL SS
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
only use the oem tbss bags. the aftermarket rub frame
