07 up tahoe guys that lowered rear come on in!!!!
cendres
AV MN
Can you guys give me some info on this thread im trying to find out something
1) What rear spring/shock set up are you using? Belltech TBSS PN 4230, no isolators, McGaughy's shocks and LCA brackets.
2) what size tires? 275/55/20, will re-measure with 22s.
3) What does it measure from ground to fender lip? 33.25
4) what year truck? 2007
5) 2wd or 4wd? 2WD
I know gm used different springs on the back of these trucks just trying to get some info on how low yours sit.
CE
Sweet_N_Low
1) What rear spring/shock set up are you using? BT 5305, OE shocks with extensions(for now)
2) what size tires? 305/45/22
3) What does it measure from ground to fenderlip?
Before drop: DF:36.5 DR:38.75 PF:36.5 PR:39.25
After drop: DF:34.25 DR:34.25 PF:34.5 PR:35.25
4) what year truck? 08 Avalanche
5) 2wd or 4wd 4WD
Tony, I used the BT 1-2/3-4 kit with no spacers on the struts and left the OE isolators in
bobwit2bs
