07 YUKON CHECK ENGINE LIGHT!
BLTZ
My 07 yukon Denali check engine light
auto zone said that the history showed P0011 twice and P0335 once
i have already replaced the camshaft positioning sensor and my light after one week is still on.
63Blackseries
Canada
Low oil levels
Dirty or contaminated oil
Low oil pressure
Oil blockage
Incorrect camshaft timing
Bad Camshaft Bearings
Faulty Oil Pump
B
BLTZ
I have also heard the engine knocking do you believe it's due to the same problem.
Also I just moved from NewMexico to Alaska and I'm wondering if the cold weather is also causing these symptoms.
Thank you 63Blackseries for coming to my aid!!!!
lalabanks80
