stabiltrak monitors all those points of input and should you have to avoid a accident, swerve hard, loose traction, etc it takes correction action to help prevent a accident so if it see's something wrong with the drivetrain it say's "hey dummy"
Hello. Not sure if this is an old post but I am currently dealing with a no crank no start on my 07 yukon 5.3. The wiring diagram would be very helpful and greatly appreciated! Guages went wild when headed to drop my son off. Made it there then the truck wouldn't crank. No idea where to start on this and can't afford to send it to a garage to sort it out. Any info and/or wiring diagrams would be helpful. Thanks in advanceYes sir that’s the module… So by any chance do you have a aftermarket radio or did the last owner have any aftermarket equipment like an alarm ( Besides the OEM keyless entry)… It’s starting to sound like there was aftermarket equipment installed and it wasn’t installed correctly… I have the complete electrical schematics from the OEM from 07-14… If you want I can email it to you… Also I have one last idea for you to try… Have you tried relearning your key??? Ive attached a link to the procedure…GM key programming
