Hey everyone!
I accidentally ran the battery in my 09 Tahoe down the other day, it’s a 6 month old AC Delco OEM battery. I gave it a jump, checked it with my scanner (Innova 3160) and it said I have a “surface charge” and to run the high beams for 5 minutes to dissipate it. Did that a couple of times actually.
I also put a charger on it because the alternator was running maxed out and couldn't make up the difference.
The standing voltage on the battery now ranges from 12.7 - 13.0 volts and the charging system is steady at 14.5 volts, but the voltage gauge is not variating like it should (and did until this happened). I took it to my local shop and the owner put his Snap On scanner on it and it’s not showing anything, all clear.
No codes, no lights and nothing on the DIC.
Will this just take a while to level out?
Is there something that needs to be reset?
Or, did I mess something up?
Any help or ideas are more than welcome! I’m scratching my head here.
Thanks,
Thanks,
