09 Yukon driver seat not working
09_4WD_YUKON
09_4WD_YUKON
The bad thing is, you CAN'T buy one with out power seats!!!
I did find out if your remove the two 15mm nuts on the front end of the cushion side, the frame pivots down giving you full access to everything underneath...or if you don't remove the seat it would probably tilt back.
Is there a sensor that goes on or somehow monitors each electric motor? I think I've got one loose as the easy exit and such is not working all the time.
jjones434
