09 Yukon hybrid rear bumper access hole
09YukonHybrid
Hello all,
I just purchased a 2009 GMC Yukon hybrid. As you know they do not all come with a spare tire. I am wanting to add one. As I was looking under the rear of the vehicle I noticed that the tube is already there that goes through the metal part of the bumper, they just did not make the access hole in the bumper cover. If I order the access hole cover (2"x2") for a regular 07-14 Yukon bumper and have a square hole drilled will that cover snap into it?
Thank you,
NathanJax
Vacation Nathan
Administrator
Jax, Fl
No you will need to do some bondo and plastic welding work. You need to cut a 6" x 6" panel off a bumper with one and mold that to your bumper.
soulsea
Bar
Yes, booth the regular Tahoe/Yukon bumper and the Escalade/Denali bumper are a straight swap, I did it on my 09 with the latter and added the spare tire kit:
the only modification you have to do is cut a slice at the top of the new bumper where it meets the quarter panel:
One last thing to keep in mind is that there were two version of the spare tire kit, one (more expensive) with the resonator relocation kit, and one (cheaper) without. I had already deleted my resonator with this exhaust tip http://store.hybridcars.com/Exhaust-Tip-Chevy-Tahoe-GMC-Yukon-p/20111.htm so I could get the cheaper kit. if you want to keep the resonator then obviously you have to get the more expensive kit of the two. I think I have the two different part numbers somewhere if you need them. Also keep in mind both kit come without a tire, but I simply went to a used tire store and picked up an almost new one installed/balanced for $50.
Hope that helps.
NathanJax
Vacation Nathan
Administrator
Jax, Fl
He's talking about just buying the little access cover panel, not the whole bumper.
NathanJax
Vacation Nathan
Administrator
Jax, Fl
That's crazy talk.
yeah. for the price of the custom work (like I posted in the 2nd post) you could get a used bumper with it already there.
09YukonHybrid
Thank you for your replies, greatly appreciated. I wonder if there is a way to mount a spare and possibly make a shorter lowering bar (instead of inserting the bar through the bumper) so you have to get under the back bumper and lower it with a ratchet handle attached to it.
SSVTahoe16
