120k maintenance tune up
adrianb
Longview, WA
That does not sound like a good or even what I would consider "fair" deal.
Charging you nearly 3 hours to change the plugs and wires? I'm a total dunce and am pretty sure I could get it done in less time than that.
Also, M3PO is correct: they should diagnose the misfire first rather than just throw money at it.
I say move on and get a 2nd opinion.
T
triumph.man
Thanks everyone! You guys saved me a lot of $$.
another question...can all the replacements listed below be done @ home w/ just an open hood? I'm somewhat mechanically inclined, and I'm sure I can replace the plugs, cables, filter. But on the other notes, don't know what a distributor cap, ignition rotors are/located. I work on my motorcycle @ home and have the general tools needed.
This is truly a great forum, and going forward may start doing a lot of easy repairs on my own, minus the oil change... :)
So here's the part breakdown with the part cost/labor cost
Distributor cap - 78/43
Ignition cable set - 213/120
Spark plug - 120/119
Ignition rotor - 18/43
Air filter element - 43/34
Fuel filter - 21/43
All parts are ac delco and labor @ 85/hr
Do these prices seem reasonable?
---------- Post added at 06:41 PM ---------- Previous post was at 06:39 PM ----------
Also reason for this tune up is because I'm having a misfire
adrianb
Longview, WA
I bet you could tackle all of that yourself with a limited set of tools and knowledge.
Online Chilton access here: http://www.tahoeyukonforum.com/forum/showthread.php?t=13127
I bet you can find everything you need to know with that resource.
Not sure who the favorite online parts dealer is these days but I know you can generally save a lot by purchasing online.
Maybe the group will have some suggestions?
Papawolflopez
