14bsf swap - U joint conversion?
sparg93
Expedition Tahoe
NJ
Unfortunately my truck is nowhere near so I can't measure...but I need to have the u joint next time i'm in the shop b/c we're doing the rear axle swap.
My rear is a '95 K2500 so I know it's a 1350...but I'm not sure what my '99 4dr 4x4 Tahoe has on the end. (but it might be a Precision 447)
I've done a bit of searching but unfortunately I haven't found exactly what mine is b/c there's a few the Chevy's put on the end. Can anyone confirm?
If anyone's interested, here's a swap writeup - http://www.4wheeloffroad.com/techar..._0610_chevrolet_tahoe_14_bolt_axle/index.html
S
sparg93
Expedition Tahoe
NJ
the answer was in your article....R3 U-joint driveshaft to mate to a 1350 U-joint yoke? No problem, that exact conversion U-joint is readily available (Precision U-Joints, PN 447).
I did :)
I was reading on another forum about a late 90's 1500 having a different ujoint that also had the 5.7l and 4l60e so I just want to make sure.
---------- Post added at 01:20 AM ---------- Previous post was Yesterday at 11:28 PM ----------
Both rockauto and summitracing are stating I have this ujoint;
http://www.summitracing.com/parts/P...r|1999|Make|CHEVROLET|Model|TAHOE&prefilter=1
here it is:
http://www.actionmachineinc.com/1350tosaginawgreasableu-joint.aspx
BigDaddy13440
Rome, NY
I had an older '90 Suburban 2wd, grenaded TWO 1/2 ton axles in a span of about 4 months. Screw trying it a third time, I upped the ante and dropped in a 3500 series van axle. I also needed the 1350 crossover u-joint to mate everything up. All I had to do was weld on a couple new spring perches on the axle (with correct pinion angles!), and transfer measurements of my shock mounts. As a bonus, the van axle was about 4" wider flange-to-flange, pushed my rear wheels out to fill up the wheelwell better.
BurbyRST
