** '15 Yukon XL Denali w/95k miles - Yes or No? **
91RS
GA
I'd pass. The mileage doesn't concern me but the year does. Try for at least a 2017.
PG01
Up here to the right
GOOSe, just curios how do you " (shift into Manual Gear 7 mode to hold it in V8 mode)? I never knew this could be done. Thanks, Keith
Pull shift lever down to furthest position and use +/- buttons to select gear you want to be in.
G00se
Newport Beach
Keith, I think 2015's only came with 6-speed transmissions. If that's the case, I would think M6 mode would work just same and keep it in V8 mode only, but maybe someone else can chime in and confirm.
DWTahoe
Colorado
When you put the Tahoe in manual mode, and select a gear on the screen, that gear is as high as the truck will shift. It will use every gear below it, the manual gear selection just keeps it from going over that gear. I don't believe it will lock out the V4 mode either. If it did, we wouldn't have a million threads about all the problems with V4 mode, people would just select m6 and never have an issue.
I'm not sure if that's whats being discussed but I know that's how that selector works. Of course I haven't tested if it will let you blow up your engine by keeping it in second gear down the highway. ;-)
08HoeCD
Life is a gamble.
If the price is low enough, you've had an evaluation done by a shop, and you're not trying to drive 30k miles per year going forward, go for it.
Tahoe14
Central Fl
2015.5 Tahoe came with the 6 speed and the 2015.5 Denali came with the 8 speed. The 2015.5 also known as the interim was produced after October 15, 2014.
16rgs
Thanks to all for the responses. I'll give it a try. Next will be tune to eliminate the V4.
WTSHARK
So. Cal.
Auto park? I had no idea the 15’s has this. I ordered a 16 and checked every box I think and I don’t have that. Interesting.
Me either, I can't just line her up and "forget" while the Yukon pulls into the parking space, but darned if I didn't get a call from my dealer (after posting this last week) that I need to come in and have it checked. Perhaps I am misunderstanding the recall, or they're using words for something else and calling it a "slow speed issue with the auto park" option. I have lane control, collision warning, and gap sensing Cruise control, but no auto park. Is it something that comes on the Denali Package? I don't know, but figured I'd schedule an appointment with my dealer, because, ya know, I have nothing else going on now anyway. ;)
BG1988
I'm considering purchasing a one owner (not a rental) '15 Yukon XL Denali w/95k miles. Truck looks clean with only minor scratches and nicks and has new tires. Drives well but only tested it at city speeds. What are the common problems to look for?
Thanks!
Jeff
90,000 highway miles = 10%
14,000miles of wear on the engine
mega0000
