1999 4x4 2 Door Tahoe
Dneel81
OKC
very nice indeed ROB. Your paint job is in much better shape than mine.
Rob Scariano
Omaha
WOW. Nice Ride
What degree shim did you use on rear differential ? Did you go with CV shaft ?
No CV on the rear. As for the shim, it changes from tear end to rear end. I didn't install the gears so I don't know the size exactly.
The driveshaft had to be extended by a little more than an inch though.
Rob Scariano
Omaha
Thanks man. I think it was repainted sometime ago. It's not showroom perfect but it's a 4X4 so it's allowed to be a lil rough around the edges. I'm planning to have linex cover the bumpers, flares, and rocker panels with Bedliner. It's a bit pricey but worth it.
Rob Scariano
Omaha
When I go to site, it only gives me the option to find a retailer....... no online ordering ...
Also, did you need any other items when you upgraded, or just gears ?
If you call Randy's and ask nicely, they will give you distributor pricing. :)
soundude
