2 Yukons with bad transmissions
When did you experience transmission problems?
  • Total voters
    30
donjetman
150k+ miles and going strong. I did change 100% of the fluid, filter, and changed the TC at 130k miles. The TC change was a preventative measure.
If I did much towing I would install a Tru-Cool Max cooler with cold wx bypass, pt# LPD4739
https://trucool.com/products/tru-cool-max
I may install one anyway just because
Bigshawn
Mercersburg, PA
I must be lucky cause I have 324,000 miles on my 01 yukon 4x4 an my trans. I have never had a problem with it. Bought it in 2009 with about 92,000 on it and as far as I know it's still the stock fluid cause I haven't flushed it or changed it since I've had it. Knocking on wood lol
Hrocks
I used have track cars and ran a lot of road courses over the years and got into the habit of changing all fluids MUCH sooner than any factory recommended intervals. I realize that track use is very different from normal driving conditions, but given stop/go, cold start short hops etc. etc., it's still demanding on your vehicle. On any cars that I have owned (vs. short term leases) I have always changed out ALL fluids regularly. My '10 LTZ has 110,000+ on it and it still starts, stops, steers and brakes like new.
02n12
Well there certainly is allot of good experiences people have had with their GM SUV. Thanks to all for the feedback. I will certainly do extra trans fluid changes and maybe extras cooling in my next SUV regardless of make.
Cooling is critical to longevity.
oldchev
Santa Maria, Ca
2004 Yukon Denali. I just turned 234,000. I bought it at 110K about 7 years ago. I have done two fluid changes on trans (with filter) and tow light (small u-haul) occasionally. I don't drive it hard and usually passed at the starting gate. Slow starts, No OD on grade (drive slower) fluid changes, all good. Anything can happen but mine works fine.
Ditto changing all other fluids. I can hear the front diff now and change fluid there every 10K. I have a good used spare on standby.
intheburbs
SE MI
Wow, 2 bad transmissions? I'm hearing in my head, "The only common denominator in all your bad relationships is you." :p
Could be the Texas heat causing the premature failure.
My '01 Burb is now owned by a buddy, has 270k miles, rusting out, but original transmission. I abused that thing so bad that it's wearing rear axle number 4, but still the original, allegedly weak, transmission.
And my '08 is closing in on 200k miles, also beat the snot out of it, have had the fluid as high as 240°, and still the original transmission.
I question the benefit of intervals shorter than 50k miles. I do 50k - trans, axles, t-case. If you're changing more frequently, I'd be curious if it's really necessary, i.e. are you checking the color/smell of the fluid? Mine still looks pretty good at 50k, and again, I'm almost always towing heavy with mine.
02n12
Well I can't say I beat the snot out of either of mine because I have not. That's the whole reason for the thread, to see what others have experienced.
My '12 looks good inside and out except for that stupid cracked dash and a small dent on driver door that I caused.
Charles Land
I just got my Yukon back after $3500 worth of transmission repair. What are the chances? I've had 2 Yukons (2002 and 2012) in the past 17 years and they both experienced the same problem. Both transmissions went out around the same mileage, about 150K miles!!!! The repair shop said XL version was brought in for the same issue while mine was being repaired, similar model year and color as mine too LOL
Have others experienced the same type of issue?
I replaced my 2002 with a 2012 and upgraded to 4X4. I've always taken care of my cars and have had other foreign makes and models last me much longer without these type of issues. I've always like the design of the Yukon over other SUVs, but this will likely be my last. With both, I've had too many major repairs besides transmission issues and other quality issues too. They've cost me too much money to own beyond purchase price.
The only reason I repaired this 2012 is because I'm giving it over to my teen son to take to college and finish running it to the ground. Hopefully it will last a couple more years before another major issue happens. Oh, but I already have something I should probably repair, bad driver side motor mount.
I have owned Suburbans and Yukons since 1984. Bought most used - a 2001 new. I have always had to overhaul trannys at 100,000 to 150,000 miles. My last overhaul of a 2011 Denali cost $2600.
David Kriss
I have a 2001 Yukon XL SLT that I bought new. The first transmission was replaced at around 150,000 miles. That one failed at around 240,000. The dealer rebuilt it. It failed about 10,000 miles later and was rebuilt again. I have to assume that failure was because the first rebuild wasn't done right. I'm at 290,000+ miles and the last one is still working. I now do filter and fluid changes every 30,000 miles with Mobil 1 Synthetic ATF. I also add some Seafoam Trans Tune a few thousand miles before a fluid change.
While I was talking with a service manager at the dealer, He said that the early 2000 series of Yukon, Tahoe, etc. were the best built series but they do have transmission problems. I rarely tow and, except for one time where I had to tow my daughter's Suzuki Aerio about 150 miles, it is never far or very heavy heavy.
lalabanks80
