20-22-24" GM Replica wheels
08grey
Tony what do the replica 24's compare to the ones I have in 22
NORCAL SS
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
depends on the tire. a 295 30 24 is 38 pounds a 305 40 22 is 45 pounds.
if you have a 22x9 escalade with a 305 40 22 and then step up to a 295 30 24 in a 24 the 24s will prob be about 1-2 pounds heavier than the 22s.
if you went from the 22x9 with 305 40 22 and went to a 24x10 with 305-35 24 that tire is 44 pounds so prob 12-13 pounds more per wheel/tire combo. I can get a exact one next week just numbers of what I remember
TriniHoe
Silver Spring, MD
Thanks, in the spring I will switch to the lighter OEM 20(s) and lighter tires. According to Tire Rack the 305 tire is 45 lbs, not sure on rim weight but it is heavy, making the combo very hard to lift up.
Chitooo
