4 Piston Big Brake Upgrade from 2019-20
MrMonte
Thanks! Also, why a 6.2? Aren't they having hella problems with the 6.2s? Honest question, I don't have an opinion one way or another.
I'm using an LS3 6.2L on my 73 Camaro so no DOD/AFM to fail. All aluminum so less weight up front and easy to get 500hp our of them while retaining great drivabilty and should get around 30mpg on the hwy in my 73.
My 2018 Yukon Denali had an AFM lifter failure at 88K miles so I deleted the system and at 115K miles with more power & better mileage.
My 2014 SS Sedan has almost 140K miles on its 6.2L LS3 and runs like new.
S33k3r
Dallas, Texas
Nice! where do you get those LS3 aluminum blocks? And is it possible without ransoming planet Earth to pay for it?
MrMonte
I watched auctions for 14 months before buying a 2011 Camaro 2SS for it's LS3 6.2L & 6 speed manual. Paid $6,400 but was too nice so I'm driving it now. 4 months later bought another 2011 Camaro 2SS for $5,300 then sold over $3,000 in parts leaving me with a great running LS3, 6 speeds manual trans, power heated leather seats, console, brake & fuel systems plus complete wiring harness.
Here's the one I kept. Even came with the carbon fiber hood.
jaxscuby
Jacksonville, FL
Do you have a 2000, 2001, 2002, 2003, 2004, 2005, or 2006?
I am just concerned you didn't see that this thread is not for your 2016.
well the previous models are using basically same parts that I can use for 2016.
the parts are from 2019-2022..so why wouldn't bolt on to my 2016.
bubbz22
I'm getting this mod completed next weekend, but did a dry fit this weekend. I'll be using these 17" wheels from the 2020+ Silverado and they clear perfectly, as I figured they would.
tc8510
WA
For the front calipers I machined some steel spacers that are 4mm thick to go between spindle mounts and the caliper to center it on the rotors. If you're going PPV 6 pistons up front i haven't done them yet.
POWER STOP Z362173 front pads
BENDIX SDR6885 front rotors
NUGEON 97P17504A/97P17504B front calipers
BENDIX SDR5729 rear rotors
POWER STOP Z261718 rear pads for SS Model
GM GENUINE 1722715/1722716 rear camaro calipers SS Model
And the link for rear caliper adapters
https://ctsvbrakeswap.com/products/...32273&pr_ref_pid=4290818211929&pr_seq=uniform
Finally getting around to upgrading the rear brakes with the parts listed.
My question is did you have to upgrade the brake lines and banjo bolts or easy swap over just change the washers?
buckwild27
If you're using the camaro calipers on the rear you will need to use the banjo bolts for the camaro calipers. Everything else should swap over. I changed all my brake hoses because they were the originals, and I've had too many brake lines blow out on me. To not change them.
Alsherooqi
