2001 GMC Yukon XL Dash Bezel Upgrade
03infantry
Hey guys,
I am new here and have a quick question. I want to put a double DIN in my 2001 GMC Yukon XL. I was wondering if anyone knows if the next generation dash bezel with the bigger radio opening will fit my 2001?
Thanks everyone!
baldd86
The 03 and up bezel will fit, but you will also need the case when doing the convertion.
Sent from my SPH-D700 using Tapatalk
baldd86
I Actually just saw the bucket and bezel for sale on gmfullsize for 80
Yukon_
Missouri
Yeah '03-'06 dash bezel, and a 'radio cage' mod is needed, I too am searching local junk yards for the parts, a dealer said -for the radio cage, you would have to buy the whole {behind the dash harness} that even goes behind the speedometer for just over $600 and to buy a replacement dash bezel thru a dealership would be $185. So ebay, or a junk yard would be a better bet. Also here is a great resource found on youtube--
http://www.youtube.com/watch?v=cbybEFH3cgg&feature=related
sparks
Tampa, FL
what about if you have the "long console" iin a denali, will an 03+ bezel fit? im dying to do the double din conversion but i dont want to get the bezel until i know it will fit ok
nhoj_yelbom
Pensacola, FL
i had a double din in my 01 without the cage.. also the cage is a PITA to get out. there is a big rivet in the back that you cant get a drill on. all i did was remove the cage, cut the back out, bolt two wood blocks on the inside on each side for a gm DD kit to bolt to and done. i cut my dash trim bezel, could not find a DD one. i just put my factory radio back in no problem, and put my kenwood in my denali.
godoy
utah
This is in my 01
Sent from my HTC VLE_U using Tapatalk 2
beka1283
