So i had a bonehead moment the other day
. I finally got the engine all buttoned up, transmission installed, new u joints installed and did my first start
. I ran through the gears on the rebuilt trans and i did not have reverse. I started freaking out, wondering what i did wrong. I had pressure checked all the apply clutches, the teflon rings were all replaced on the pump. I knew I had to drop the pan and see if i could find any obvious problems. Well, I found it
The boost valve retaining clip was not seated properly during install. I just got sloppy at the end of my rebuild. There was a false ledge that i thought was where the C clip went. This time I made sure to get it fully seated and used a hook pick to verify it was in the groove. I now have reverse and the engine is running. It has almost been a year since i started the engine and transmission rebuild and it feels great to have her back again. I now just need to get her inspected and to have all of the emission readiness monitors checked. I have one drive cycle to do, and the Tech2 will do the EVAP test. All others are done.
