2002 Tahoe LS 4x4 oil pan gasket change
SnowDrifter
Washington. The starbucks side not the desert side
It's annoying / messy but not a hard job
Loosen front diff, support with jack
Unclip harness from front of engine
Remove bolts securing brackets to trans lines
Remove plastic inspection covers on the bell housing
Zip the bolts off, mind that there are some bell housing bolts on there too
Jiggle wiggle it off, get under it, push the diff out of the way with your right foot, slide back of pan down and back and it pops off
Clean the fawk out of the mating surfaces. Give the guts an inspection. Do your oil pump o-ring while you're in there (When you seat it, push hard. Takes like 25lbs of force to get the o ring to pop in).
Dab of RTV in the corners (hondabond / threebond) where the covers meet the block
Toss the pan up, spend some time walking it back and forth between the bell housing bolts and snugging it to the block
Torque to spec. Go around again. Go around again
Toss the rest of the shit back together
Go grab a beer or take a nap or whatever. Give the RTV a day to cure before you fill it up
Fill with oil and bob's your auntie
If you want more details / specs let me know
Livebai8
Livebai8
Houston, Texas
Thanks for the tips! I'm going to get under there and study it first...then plan a day for it.
Sent from my SM-N920T using Tapatalk
Livebai8
Livebai8
Houston, Texas
Spoken lie a true DIY'er. Good luck.
Have you seen or done this via lifting the Engine? I saw another post about loosening or removing the bolts from the motor mounts and using floor jack on the harmonic balancer to lift the motor for the clearance?? Any thoughs?
OR VietVet
GMT800 SUV/Trucks
Military
Willamette Valley
I would not do that. Lifting and supporting at the balancer is not recommended and dropping other obstacles down out of the way, IS.
Livebai8
Livebai8
Houston, Texas
Apparently you only use that area to lift, then use block wood 2x4 I imagine between the mount and
Motor. Just wasn't sure if anyone has actually tried this method or not.
OR VietVet
GMT800 SUV/Trucks
Military
Willamette Valley
Ok, you are going to do what you are going to do but remember that none of us said to do what you may be thinking of.
South Carolina
Did this recently on an 04 silverado 4x4. We just took the diff mount bolts loose and let is hang a bit and there was plenty of room to wiggle the pan out. +2 on the o-ring. This was the reason my 05 suburban had oil pressure issues. Air was getting in past the o-ring and foaming up the oil when it was cold. No issues after the fix. Good luck with your pan. Make sure you clean out any sludge you have in there before putting it back in.
andrewjles
