2003 Escalade will barely start and/or run... dtc p0120 p0220 p1515 p1516 p2135
GM_LUVA
She'd been sitting 4-5 years.. new fuel pump, battery, plugs and wires, good compression. Throws all these codes every time.. p0118, p0120, p0220, p1515, p1516, p2135
S33k3r
Dallas, Texas
Have you looked up what the codes mean? Many times there will even be YouTube videos on troubleshooting and fixing them. I'm mobile at the moment, so not in a good position to search. Regardless, other things to consider may be a stuck throttle body (stuck mostly closed), a clogged intake, bad knock sensors, etc. -- things that would be in the air/fuel path that can have issues after the vehicle has been sitting a while.
Good luck, in any case and, to be clear, I'm just guessing as I have not researced those codes recently.
Welcome to the Forum from NH.
Pics of the truck, please.
I cannot personally help you with your question; however, other members on this Forum that are much more knowledgeable than me will chime in.
macking
