2003 Suburban Erratic Voltage Meter Readings
pwol1962
Arlington, TX
My 120,000-mile 2003 Suburban voltage meter readings frequently indicate more than 18 volts and then the needle is pegged at maximum. Whenever this happens, which is frequently, the voltage meter needle never returns to zero when the engine is off.
When the voltage meter doesn't return to zero volts ahd reflects 16 volts with the engine off, it will go to maximum when the engine is started.
Whatever the voltmeter reflects with the engine off, when the engine is started the voltage meter needle advances the amount which would be the same as it would to indicate charging at 14 volts. Occasionally the voltage meter will work normally.
I suspect the issue could be the printed wiring board in the instrument cluster having a cold solder joint or a ground issue. This has been happening for the past 5 months.
When it's acting up, confirm the voltage at the battery with a voltmeter.
If the cluster has never been rebuilt, it will need new stepper motors for the gauges. Do all of them while you're in there, and fix any burned out backlights or convert them to LED.
There could be solder joint issues, too, but the stepper motor issue is very common in these clusters. There is also an issue with "silver migration," where the circuit board traces are compromised by, well, silver migration. Typically that can be cured by a careful washing of the circuit board with a very soft brush and some isopropyl alcohol. While you're in there. A good cluster rebuild service could do all of this for you.
justirv
As @Fless stated... verify actual voltage, then go thru the cluster as suggested. There are stepper motor/LED kits available. 2003 was the start of using stepper motors, 2002 and earlier clusters have old-school air-core motors. Several reputable places do get them refurbished as well. I drove mine around for a week or so without a cluster while it was out...
pwol1962
pwol1962
Arlington, TX
Thanks to everyone for the recommendations. The actual voltage output at the alternator has always been good. I will remove the instrument cluster, clean it with isopropyl alcohol and replace the stepper motors, which are listed on eBay.
One tip I would suggest is, right before you pry the gauge needles off of the cluster face, somewhat gently rotate the needle full counterclockwise (you'll feel it hit the end of its range, and that will probably be a bit below the lowest gauge mark). Then stick a small piece of painter's tape to the gauge face underneath the tip of the needle, and mark that full left position on the tape. That will save you from having to guess where the needles should be indexed when you put them back on.
pwol1962
pwol1962
Arlington, TX
Thank you for this important recommendation. I previously removed the instrument cluster last year to fix transmission display connection on the printed wiring board and ended up with the fuel the gauge and rpm needles incorrectly reinstalled. Now I can index the correct needle positions when I install the 5 stepper motors.
Jtwins
