2003 yukon denali build
D
Duramax05blk
NH
pic 1 factory sound deadner foam
pic 2 factory deadner
pic 3 deadner in front.. little helper hiding
pic 4 Carpet in and all cleaned
D
Duramax05blk
NH
pic 1 turning the radiator adapters to mate an fittings to the factory threaded ends
pic 2 adapters all tig welded
pic 3 cooler lines
pic 4 oil cooler lines
D
Duramax05blk
NH
nasty pic but shows trans lines. they are mounted to the firewall to prevent contact with exhaust. they will be mounted to the inner fender liner via hose clamps with xmass tree ends can think of the actual name.
D
Duramax05blk
NH
quick shots of fabbing up trailing arms. lower arms are using the barnes enduro joints and the uppers and panhard are using barnes standard heim joints.
D
Duramax05blk
NH
the uppers are extremely close to tire on stock offset with 1.5 diameter tube and no bend heims line up perfect though. i have added spacers for the time being.
D
Duramax05blk
NH
Trailing arms powder coated
Sent from my SM-G900V using Tapatalk
D
Duramax05blk
NH
pulled rear end to clean up and removed shafts to replace backing plates
Kind of odd to me but the new z71 springs are shorten then the factory denali springs but z71 springs are much stiffer, escpecially considering the air ride had been bad for a few years.
got new shafts back in, spray bombed new z71 springs and calipers with new pads and rotors and speed bleeders. Also got stainless braided hoses on and new copper line run along axle
Snefferz
