2003 yukon denali build
D
Duramax05blk
NH
before deciding to go white underneath i paint matched the center link, front sway bar, trans mount, engine crossmember. horrible pic to much light in the booth
D
Duramax05blk
NH
the rough country tie rod sleeves would not fit the new moog inner and outer tie rods a little lathe persuasion was required
TheAutumnWind
pulled rear end to clean up and removed shafts to replace backing plates
Kind of odd to me but the new z71 springs are shorten then the factory denali springs but z71 springs are much stiffer, escpecially considering the air ride had been bad for a few years.
got new shafts back in, spray bombed new z71 springs and calipers with new pads and rotors and speed bleeders. Also got stainless braided hoses on and new copper line run along axle
Odd, my denali springs were definitely shorter than my moog z71 replacements.
D
Duramax05blk
NH
odd they are moog 81069 which i believe are z71 ordered from summit
D
Duramax05blk
NH
the moog are little bigger in diameter i believe that is part of there "problem solver" upgrade over gm
1992rs
OR
Sub'd. What did you use for a top mount on your coil-over conversion?
D
Duramax05blk
NH
I'm going to try atomics newer top utilizing the factory mount
Sent from my SM-G900V using Tapatalk
1992rs
OR
Sweet. Looking forward to see how it works out. I would love to ditch the t-bars and go coils one day
Mike4400
