Huge caliper. Gonna do a write up on the install Dan?The good news is it's fixed for now and blowing cold. Also mocked up for the 21+ front calipers. They fit the ltz20s with a 1/4" spacer.
View attachment 277895 View attachment 277896View attachment 277901
Doesn't sound bad.Probably do something but it will be a while my current Powerstop setup has tens of thousands of miles left so I'm not overly motivated to order the pads and rotors. Plus I was having trouble finding slotted rotors when I looked the other day. I personally feel slotted/ drilled is pointless but it looks good and that's the main reason for doing these anyway lol.
Also not much to write up you literally just bolt them on with a single washer between the caliper and bracket. It's as easy as a regular brake job as far as I can tell.
Doesn't sound bad.
your front axles are missing
Sucks you got run a wheel spacer for that upgrade![]()
I know any minute now the bearing will collapse sending my wheel ahead of me in traffic
I have a feeling the set I have coming that has the hump completely shaved will fit but, it might be too close for comfort. If I have to run spacers I may get a hub-centric set the 1/4" set I have is about as cheap as it gets.
