2004 6.0 NV4500 Tahoe
Ok I definitely want to look into desensitizing the misfire readings because it seems to be BS IMO. I think before the weird startup driveability problems maybe have been a bad plug wire because that’s totally gone *knocks on wood*. The 4k Misfires has got to be BS since it only happens at idle and the idle feels rock solid.
How do I mess with these tables? Add or subtract? Where? And how much?
Have you done a CKP relearn? Supposedly that helps the ECM to detect misfires accurately.
pwtr02ss
Tennessee
Interesting. Well, I gave it all sorts of RPM and throttle inputs. I hope it's not tuned out that much. Do you know where I'd find this info?
When I was doing all my reading about tuning for the transmission and a stall. I can't remember exactly what I did though. I may have only had it report misfires in gear or above so much RPM. IIRC I just googled "tuning for stall" or something like that.
Like everything, there's a million different ways people do things in tuning. I could have read some BS thats wrong. So far, mine doesn't have CEL and it seems to drive/lock up fine....
EDIT: Open YOUR tune and look at your misfire tables under engine diagnostics>misfires>and look at the tables....
Compare those to the stock avalanche tune I sent you WAY back when. You'll see what I'm talking about.
I didn't want to post your tune....
I think you can do that with HPT...
Coincidentally, I was just discussing this a few minutes ago with a buddy that swapped a G8 GT drivetrain (L76/6L80) into an ex-Frito Lay delivery truck (food/kitchen truck for his business). He has EFI Live and says he can do a CASE relearn with it.
pwtr02ss
Tennessee
You can supposedly do the same in hpt in the scanner functions. Hopefully big d will get his sorted out without having to do it
Mily
