2004 6.0 NV4500 Tahoe
I see Hellwig uses that same hammered finish that DJM uses. When I bought mine I remember checking the specs and they’re nearly identical. But they sure are heavy compared to stock, no comparison.
Dantheman1540
Dantheman1540
Sugar Loaf Mountain
Your not kidding they are heavy! Double the weight easily. You think DJM and Hellwig sell the same bar? I really dislike the hammer finish it always seems to catch more dirt and road grime since its porous. So it will get the sparkly silver like the LCAs.
Not sure but the specs are nearly identical and they look exactly the same.
Dantheman1540
Dantheman1540
Sugar Loaf Mountain
I looked up the Hellwig rear sway bar on Amazon--https://www.amazon.com/dp/B003LFF20Y/ref=cm_sw_r_apa_i_NNmTEb4ZMXGNB
$364. Did you get it cheaper? The front bar is something like $242.
Dang I thought I got it for about $300 I guess it was $360 then the 10% bumped it down to $330. I try not to keep track of my parts spending so I don't get sick.
Hellwig is solid, factory is hollow.
For some reason you just made me want to cut the factory one in half and see how thick the walls are.
Abelton
