2004 6.0 NV4500 Tahoe
Dantheman1540
Dantheman1540
Sugar Loaf Mountain
I really do. I try to get focused on learning it, I just have a mental block. Once I think I can't figure something out, I have a real issue getting past that. I also don't wanna ask a million questions and annoy you or Randy
I don’t speak gen 4 so I’m no help lol. I totally get the mental block tho.
Head chambers are 63cc which is perfect for 10.4:1 with the .041 gaskets.
I misspoke and subtracted instead of adding the gasket thickness to the deck clearance. Quench should be safe at .045-.049 depending on deck height.
Gasket thiccness minus piston height. So, .041" - .006" = .035" (bare minimum, maybe dangerously close, maybe damagingly close)
If piston height is .008", that puts you at .037" which is in the safe zone. You should check with modeling clay as an extra measure. Don't forget to rock the piston when getting your measurements.
Dantheman1540
Dantheman1540
Sugar Loaf Mountain
Ok ok hang on, so summit says it’s clearance plus gasket thicccness. If the deck clearance is +.008 wouldn’t that be .008+.041=.049?
Or because it’s positively out of the cylinder, meaning sticking up like a hard ****** .008 that means you need to subtract it because it obviously makes the quench volume less. Meaning .008-.041=.033/danger. I think this is correct and is what my initial thoughts were but then the summit wording got my panties in a bunch.
So if that’s the case the .041 gaskets are probably too thin to be safe but your saying I could check with modeling clay how? Put the heads on with clay on the piston and turn the crank over sinking the valves into the clay and then pull the heads off and measure compressed clay thicccness?
Thank you for your patients kind sir.
You have NEGATIVE deck clearance when the piston comes outta the hole. So, you subtract .008" or whatever your clearance measures out to be. I have a bad habit of calling it "piston height", which is not technically correct. Piston height is the measurement from the center of the pin to the top of the piston.
Modeling clay lets you see the quench height but it's primarily for seeing PTV clearance. So, it's a two-fold benefit. I used an old stock gasket (.051" compressed), put some modeling clay on top of the piston (smeared a light coat of oil on piston and in chamber) and cinched the head down with old head bolts. I didn't fully torque them, obviously, but got kinda close. I turned the crank slowly by hand a couple times then pulled the head. I carefully sliced the clay with an X-Acto knife (using more pushing of the blade than dragging it) and measured the cut cross sections at the head surface and at each valve with a digital caliper. You have to use modeling clay- not Play-Doh, etc. I subtracted .006" from my measurements since I was planning on .045" gaskets.
OH! I forgot- you need to use solid lifters. I took apart two of my stock non-AFM lifters, flipped one of the pieces inside around (I don't recall the proper name of the piece) and reassembled them to make "solid" lifters.
Dantheman1540
Dantheman1540
Sugar Loaf Mountain
Ok, we are on the same page now, I suppose the best-case scenario would be that the deck clearance is only .004 and I can run the .041 with a quench of .037. Somewhat unlikely tho I suppose, I guess I'll go ahead and order some .045s and return whichever I don't use. Kinda sucks because I wanted the CR to be the same between the heads to eliminate that variable from the swap.
I think I have one solid converted lifter to measure pushrod length with but I might have to scrounge for a second.
Dantheman1540
Dantheman1540
Sugar Loaf Mountain
When I bought those I was finally confident my burned plug wires were a thing of the past. Glad you like them. They’ve worked perfect for me, going on 2 years I believe.
First set of wires that don’t touch anything except the thing they are plugged into! Plus they are just really nicely done I’ll get a set for the RCSB as well. Thank for the tip! :beer:
Austin12
