2004 Tahoe fuel issues.
fiatdale
Houstons Best
Houston
Not necessary to remove the shaft. Just stress to be careful disconnecting lines. They can get brittle and break - so just take your time. Make sure you raise the vehicle up high enough to get the tank out from underneath it.
a4edwin
ny
Don't know if you have an evaporate canister it's a black rectangular box. Next to the fuel tank in the front. I've heard some don't have it. But if you do there's a hose that's connected to the fuel tank you need to disconnect it. I pulled my tank out not knowing it was hooked up and broke the Nicole off the box a 200 dollar mistake! But it really easy to do only pain was putting the tank back in a helping hand would have been welcomed. Just to put the straps back on.
J
JFranks
Alabama
I swapped my pump in about 2 hours. That's minus the 3 hours to pump the tank out with the small pump I borrowed! I backed the rear onto some ramps and lowered just the backside of the tank. It was a little tight but I got it replaced. If I could have raised it about 6inches higher it would have taken half the time. I had to pull the filler tube off the tank to get the anti siphon screen out before I could start draining. All in all it was a fairly easy job. It's been two weeks and the truck hasn't had any issues and has more power.
Red Rider
So I did the job Sunday. Took about 3 hrs, not counting the trip to the parts store to get a new lockring (ordered wrong one). Most time was 'figuring it out' so to speak.
I tested the fuel pressure and it holds once primed, but pressure is about the same. 42-45 psi. I have not yet changed fuel filter. I will do that after our trip this weekend. I was afraid of damaging the fuel line. In retrospect, should have done it when system was apart....
I will do a write up of my experience (mostly for myself if i ever have to do this again).
Chizzychase
I've always thought 42-45 psi was in spec for these models, but I'm not sure.
Red Rider
I thought it was higher. But I could not find the FSM section on the fuel. Swear I saw it before but could not find it anywhere.
joo3yy133
