2004 Tahoe Security Glitch
ojb226
Hey folks. 2004 Tahoe Z71 with 320K on the clock.
THE FOB IS NOT THE PROBLEM... I've tried multiple new OEM fobs..
on the driver door, the lock button does not work. the unlock button does.
on the passenger door, the lock button does work. the unlock button does not.
on the fob, the lock button works, but the unlock button does.
any ideas on the issue? I've looked into a VIPER alarm system but a technician recommended not doing it unless i solve the core issue first. Do you think if i do a ECU/PCM swap that would fix it?
Thanks in advance.
Thanks in advance.
sounds like time to try some door switches, the junkyard is your friend.
I would try the master switch first and see if that allows the passenger side to work properly
the switches are tied into the master, so if the master is bad the others "may" not work correctly.
pretty unlikely to be anything else unless of course the actuator is bad, "maybe" a relay. but less likely.
O
ojb226
Thank you!
Those master switch modules are pretty pricey on eBay and they’ve all been ripped out in my local yard.
I will keep looking!
There is a nationwide salvage yard parts network that can find and ship parts to you, if they are not available locally. Did you ask your local salvage yard about it?
Thank you!
what search parameters are you using on ebay? the switch should be the same for the most part for 03-06 across the board including silverado/sierra/avalanche
non power/power fold mirror switch I believe is the only difference (but i could be wrong)
also trim color doesn't matter because the switch just clips on
so you could find it under
03
2003
04
2004
05
2005
06
2006
tahoe, yukon, suburban. silverado, sierra, avalanche
unsure on the escalade switch being compatible or not
O
ojb226
03
2003
04
2004
05
2005
06
2006
thanks Doubeleive!
Just ordered one off ebay for $60. For some reason the last time i looked I only found OEM remans that were north of $200!
I will let you all know if that was the problem after I get it installed next week.
Youkon_Guy
