2005 Crown Victoria P71 Build
95escahoe
95escahoe
Then I picked up some Magnaflow tips and had those installed and did the bumper tuck, didn’t tuck it up as much as I’d like due to some damage to the bumper that I’ll replace down the road
Sam Harris
Texas
Damn! Nice ..!
What the hell.. no audio / video clips!??? We want before / after..!
95escahoe
95escahoe
I added the missing shield that goes over the radiator, along with a shorter antenna I got from American Muscle for a 94-04 Mustang, then a few days after these pics I blew the trans and had it rebuilt it lost 3rd and 4th, was out getting some food pulled out onto the road and I’m under WOT a car cut me off and went to floor it and pass them as they turned off and wouldn’t go over 50 mph and from reading about these transmissions I knew it was toast, it would just got up to 2nd then rev like it’s in neutral but with the OD turned off it would get into 3rd so I could atleast drive it to the shop instead of getting it towed, got it back a week latter, when they rebuilt it they discovered a snap ring broke and that’s what did the trans in
95escahoe
95escahoe
The Crown Vic has rubber flooring I’ve always had some cheap Autozone floor mats on top to keep the car a lil nicer looking and cleaner I picked up some CG products and cleaned up the flooring and it came out mint and picked up a cleaner steering wheel since the old one was pretty worn and installed that
95escahoe
95escahoe
So the spotlight would turn on and it when you’d rotate the handle you’d really have to rotate it to get it to move and even then it didn’t fully move side to side, so I picked up a new handle and screw and it worked mint, you can see how worn the old handle was and how it wouldn’t fit the shaft like it should to turn the light
95escahoe
95escahoe
The power steering fluid was dark and nasty looking so grabbed the syringe and sucked it out and topped it off did this a few times over the course of a few weeks and got all the bad fluid out, then I picked up some Whelen mirror beams with amber lights and put them on, I’d like to hook them up as running lights/turn signals but for the time being they aren’t hooked up
clublub69
