2005 Suburban 1500 LT - Electrical Mystery?
markman57
We are at our wit's end trying to get our 2005 Suburban starting consistently again.
  • Have replaced the alternator and battery but it is more complicated than that.
  • Also, cleaned the PCM. There really wasn't much corrosion present. That seemed to get the burb starting correctly for about 1 day.
  • Tested the following grounds that seem solid: negative battery to under driver side radiator, ground to hood, ground to back of engine (large braided ground wire). Are there other ones?
  • Replaced fan assembly and related relays. That was definitely a misdirection and poor $ spend!!
I don't know if I have a hard to locate parasitic power drain or possible just a bad PCM. That sort of feels like the problem but would like to validate it before replacing. Maybe a squirrrel got under the fuse box and gnawed on some of the wires....hope not
I am new to the forum although I have owned different 3 Suburbans since 2004. Kind of speaks to their reliability since I am just now on the forum for help. Also, my son is a young car mechanic now so we have fun tackling these things DIY.
my 04 Tahoe z71 kept draining my battery and my resolution was to replace the key switch in the steering column not the tumbler that takes the key but there is a component next to that , a cheap fix and easy to replace , thanks to YouTube for the analyzes
brilamb21
