2006 Tahoe Lift Gate Issue
ayeplussjr
Sacramento, CA
The liftgate on my 2006 Tahoe stopped functioning. I can no longer open my rear lift gate. The actuator was replaced less than a year ago and it stopped functioning again. Can it be another bad actuator in less than a year?
For some odd reason are there no liftgate locks on the 2006 models? I cannot find the lock anywhere to try and open the liftgate manually.
Any suggestions?
I found a couple of other threads but no resolution.
dropmech
Puddle Pirate
Coral Springs
Those struts go bad every now and then. I had a broom stick to prop mine up at one point. That's probably one of the things you'll replace the most on your tahoe.
lilsolo68
tyler,tx
i just replaced the struts on my 00 yukon and every time i open it i have step back to keep the door from hitting me.
carisaandjoe
check out this blog - it describes exactly what is happening.
http://www.chefseattle.com/blog/site-news/suburban-rear-liftgate-wont-unlock-how-to-fix/
I have the same issue with my 2006 Yukon XL. I temporarily set it to unlock mode and then unplugged it until I get a new one. The GM part number is 15808595. The cheapest I can find it is on gmpartsdirect for almost $250. I am waiting to see if an aftermarket one will come available soon.
ed70805
